I took it and had it check at autozone and at Kwik Kar. The test at both places said,
Random Cylinder misfire detected probable cause
001 Weak/msiising spark
002 Plugged fuel injector
003 Engine Mechanical fault
004 Large vacuum leak specific to cylinder
or
001 Lean Air/fuel ratio-ruel pump
002 Faulty MAF/VAF sensor
003 Large vacuum leak
004 Ignition system fault
Kwik Kar said I needed a tune up so I did the tune up for $70.00 and the car still idled rough and engine light flahing so they said I needed a new motor. So I guess it was driven to long with the engine light flashing to get home.
What do you think?
Tuesday, May 12th, 2009 AT 9:15 PM
