Stalling / Rough idle
AH
2002 Camry; 60,000 miles. For the record, I recently had 60K service done but it's unrelated to my problem. Every once in a while car stalls in stop and go traffic or when coming to a stop. The check engine light doesn't go on. Runs OK at higher speed but stalls and quits when coming to a stop. It starts up right away but dies again at the next stop. This only happens once in a while. Last time it happened, I took it to the dealership while it had the rough idle. Of course when they checked it the next day, they couldn't replicate the problem and the computer doesn't show any problems. The dealership kept the car for three days without a successful replication so they gave me the car back without charge. However I fear that the problem is still there and will lurk its ugly head soon. Your help is greatly appreciated.
Apr 26, 2007 at 4:26 AM
  • 75,988 POSTS
[quote:09dc2ad7fd="AH"]2002 Camry; 60,000 miles. For the record, I recently had 60K service done but it's unrelated to my problem. Every once in a while car stalls in stop and go traffic or when coming to a stop. The check engine light doesn't go on. Runs OK at higher speed but stalls and quits when coming to a stop. It starts up right away but dies again at the next stop. This only happens once in a while. Last time it happened, I took it to the dealership while it had the rough idle. Of course when they checked it the next day, they couldn't replicate the problem and the computer doesn't show any problems. The dealership kept the car for three days without a successful replication so they gave me the car back without charge. However I fear that the problem is still there and will lurk its ugly head soon. Your help is greatly appreciated.[/quote:09dc2ad7fd]
Have the EGR system check
Apr 26, 2007 at 9:04 AM
AH
Thanks for your response. I failed to mention that the car won't die if I step on the gas while in "P" or "N" although it does have a rough idle when it has these episodes. Also this has happened about 3 times so far each about 2 weeks apart. I was thinking it could be the IAC valve or motor or the MAF sensor after reading a bunch of the other questions. Should I have those checked out? However, if you feel it's the EGR system, I'll have that checked out. Again, I appreciate your help.
Apr 26, 2007 at 2:02 PM
  • 75,988 POSTS
[quote:41b00ba243="AH"]Thanks for your response. I failed to mention that the car won't die if I step on the gas while in "P" or "N" although it does have a rough idle when it has these episodes. Also this has happened about 3 times so far each about 2 weeks apart. I was thinking it could be the IAC valve or motor or the MAF sensor after reading a bunch of the other questions. Should I have those checked out? However, if you feel it's the EGR system, I'll have that checked out. Again, I appreciate your help.[/quote:41b00ba243]
Have them check for a sticking/binding throttle plate,IACV,TPS,MAF/IAT,EGR,CTS and O2 sensors. Also get them to scan the computer maybe there's something in there that can give them a headstart.
Sorry, sounds like the whole entire TCCS
Apr 26, 2007 at 2:25 PM
