1996 Toyota Camry Rattle in rear especially when climate is
WAJANSEN
  • 1996 TOYOTA CAMRY
  • 6 CYL
  • 162,000 MILES
Rattles in rear more in cold weather
Sunday, February 22nd, 2009 AT 5:44 PM
F4I_GUY
  • 3,302 POSTS
First I would check if it is your exhaust system. It could be a rusted off heat shield, a broken hanger or something loose internally in the exhaust system.
If that is not the case and it's more of a suspension clunk, look at your struts, stabilizer bar endlinks and bushings, things of that nature.
Goodluck.
Sunday, February 22nd, 2009 AT 5:53 PM
GFIMOTORCARS
  • 673 POSTS
I would have to concur that if you are experiencing a rattle from the rear of the vehicle it is probably exhaust related. Check the exhaust hanger, heat shields. Also if you have a rubber mallet, raise the vehicle and hit the catalytic converter with the mallet. If you here something rattling in the exhaust you have a failed catalytic converter. Often times these will break apart internally and cause rattling in the vehicle.
Tuesday, February 24th, 2009 AT 8:35 PM
ERYNANDIRELYN
I just had the same problem with my 1996 Camry, the sway bar bushings were shot. I had them replaced and no mor noise.
Sunday, March 1st, 2009 AT 2:33 PM
