Hi
this toyota has a rattle in the rear end. Sounds liike something banging under the trunk when I hit a bump. I looked under the car and every thing seems ok.
Thank you
mike
Saturday, November 15th, 2008 AT 9:27 AM
JAMES W.
MECHANIC
Mike, Check for a loose, or worn, rear strut mount. Most common cause is a broken exhaust hanger allowing the pipe or muffler to hit the body or suspension.
Saturday, November 15th, 2008 AT 1:20 PM
TOYOTECH
MEMBER
The rear sway bar bushings wear and can't tightly hold the sway bar causing a rattling sound over bumps.
