After driving for about an hour I can hear a rattle from the Engine
225,000 MILES • 2.4L • 6 CYL • FWD • AUTOMATIC
SAMUEL41414
Engine started to rattle after about an hour drive out of the blue. Stop at gas station and when I got back in it started the rattle noise. I took of belt and replaced tensioner plate and pulley. Sound not coming from alternator or other pulleys. Seems like it is coming from front of engine.
Oct 11, 2016 at 7:23 AM
  • 31,937 POSTS
First make sure it is not low oil pressure causing the noise, if that is okay, you will have to pull the timing cover off and inspect here if you thing that the noise is from the front of the engine and not external belt related.
Oct 11, 2016 at 6:46 PM
