1996 Toyota Camry Oil Leak
HBOLANOS
  • 1996 TOYOTA CAMRY
  • 4 CYL
  • 245,000 MILES
Hi, Mr. Technician my name is Howard, I own a 96 Toyota Camry with 245000 miles. I notice that it had oil leaking from the bottom. I changed the head gaskets and still leaks. Recently it overheated as I was coming home from work. I changed the heat switch next to radiator and also changed water pump. My question is if after changing all of these parts what could be the trouble on my car?
Sunday, May 23rd, 2010 AT 8:38 AM
Hi hbolanos, Welcome to 2carpros and TY for the donation
I need to know where exactly is this oil leaking at lacking engine oil will cause the engine to overheat.
Your overheating problem could also be coming from a stuck closed thermostat, a radiator that's clogged, a blown headgasket and cracked head or block and intake leak, could also be airlock. If everything here checks out-Get it block and pressure tested.
Sunday, May 23rd, 2010 AT 6:20 PM
