1996 Toyota Camry car cut off
KAY9325
  • 1996 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 128,000 MILES
Yesterday while I was driving down the street the car just cut off so I figured it to be the battery but it has power all the lights work. Tried giving it a jump but still not starting.
Thursday, December 4th, 2008 AT 1:26 PM
Try below and comeback with some results
Get a starting fluid or ether and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Thursday, December 4th, 2008 AT 2:21 PM
