1996 Toyota Camry break in
GIRLPWN
  • 1996 TOYOTA CAMRY
  • 6 CYL
  • FWD
  • 203,518 MILES
My doors won't unlock.
I'm stuck in alaska and if I can avoid paying the cab company 40$ to break into my car, I want too.
I have a wire hanger, and my locks are just not unlocking >:\
My driver door was always not wanting to unlock, and my passenger door JUST started.
anyway it's cold and I NEED to get in!
can you suggest anything?
Monday, December 8th, 2008 AT 12:26 PM
DSPLC
  • 220 POSTS
If your key just would not turn when you insert it in the door key slot, then the teeths inside the key slot are stucked. You need to spray the key slot with W-40 oil lubricant. Keep shaking the key inside the key slot until it turns.
Now, if the key is turning. Then you have to use a slim jim or improvise something like the on the link below. Lock pick topic
http://en.wikipedia.org/wiki/Slim_Jim_(lock_pick)
Monday, December 8th, 2008 AT 7:12 PM
GIRLPWN
Wooot !
I didn't think about wd 40 but
I did use some rubbing alcohol?
Only a girl would do sucha thing.
Ahh thanks alot though :)
Monday, December 8th, 2008 AT 7:23 PM
