95 toyota camry door locks malfunctioning
MITCHELLMOORE
when the car is either being driven or parked, the power door locks unlock repeatedly at any given time.
if you lock the car... and walk away the unlock on their own, sometimes over and over and just remain unlocked.
what is the problem and how can it be fixed?
Feb 4, 2006 at 4:30 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Please clarify whether the locking or alarm equipment is factory-installed or aftermarket, and provide any existing diagnostic findings.
Guidance references and applicability
Source: Original question and visible replies. Owner reports and other participants' experiences are distinguished. Next steps are editorial requests for clarification or existing diagnostic findings, not a verified repair procedure or an independently confirmed component diagnosis.
Read the replies · Discussion summary and reported outcome
CMNETWORX
  • 7 POSTS
Have you checked the lock switches in the door? It is possible one of them is shorting out, or jammed. One simple test would be to disconnect the housing on the back of both switches and see if the locks still automatically unlock..
Feb 14, 2006 at 10:10 AM
Discussion summary
The owner reports that a 1995 Toyota Camry's power door locks repeatedly unlock without command while parked or driving. They can also unlock after the owner locks the car and walks away.
Reported outcome: No confirmed repair or resolution was reported.
A reply suggested a faulty door-lock switch, but no findings confirmed that suggestion. The installed alarm or remote-locking equipment was not identified.
Read the original discussion
