1996 Toyota Camry
AUSTIN50
  • 1996 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 125,350 MILES
On cold mornings the engine cuts off, unless you hold the gas pedal for one and half mins. Then it maintains idle. Guys could this be related to the EGR cir. Or does this car have a cold start vavle. Once warm she runs fine. Thanks, austin50
Wednesday, December 26th, 2007 AT 3:40 PM
BMRFIXIT
  • 19,053 POSTS
Idle air control valve
you should start by cleaning it
you may have to remove it and clean it with carb clean
very common
Wednesday, December 26th, 2007 AT 8:11 PM
