1996 Toyota Camry
DEMARIUS
  • 1996 TOYOTA CAMRY
Engine Performance problem
1996 Toyota Camry 4 cyl Automatic
Hey, My car will crank but only stays on for like 5 seconds then dies. I cant drive it to a shop or anything. What could it be?
Wednesday, April 21st, 2010 AT 11:15 AM
Do you hear the fuel pump come on when key at on position-if so check the fuel pressure to rule out the fuel filter and fuel pump if not check and test the airflow meter, circuit opening relay, EFI relay and EFI fuse.
Wednesday, April 21st, 2010 AT 12:36 PM
