1996 Toyota Camry 4 cyl Automatic 160000 miles
I JUST BOUGHT A USED 1996 TOYOTA CAMRY AND AT FIRST THE CAR RAN GOOD. THROUGH TIME WHEN THE STEERING WHEEL BEGAN TO MAKE NOISE WHEN I TURNED IT. I HAD THE MECHANIC LOOK AND SAID IT WAS A PUMP THAT NEED TO BE CHANGED, BUT NOW THE CHECK ENGINE LIGHT IS ON AND CAR SEEMS TO SHAKE WHEN AT A STOP, THEN WHEN I BEGIN TO DRIVE IT- DRIVES OFF SLOWLY AT FIRST THEN GOES QUICKER. WHEN AT A HIGHER SPEED SOMETIMES IT SEEMS TO HAVE A MOTION OF SLOW THEN QUICK, SLOW THEN QUICK. WHEN USED TO MUCH, OR TO LONG OR WHEN AIR CONDITIONER IS ON IT BEGINS TO SHAKE AGAIN, LIKE IT IT WANTS TO TURN OFF OR RUNNING OUT OF GAS. WHAT CAN THIS BE AND HOW EXPENSIVE CAN THIS GET?
SPONSORED LINKS
Thursday, May 29th, 2008 AT 4:42 PM
