1996 Toyota Camry 4 cyl Front Wheel Drive Automatic 174k miles
My problem is car won't pass smog check. Was analyzed and message P0401 EGR Flow Insufficient shows up. I want to fix problem my self. What steps should I take to check and repair or replace the EGR valve, the EGR Modulator and the VSV? Also where is the VSV located on this car? Thank You for considering my question. My email address is rp677@flash. Net.
SPONSORED LINKS
Tuesday, January 22nd, 2008 AT 11:42 AM
