1996 Toyota Camry Check Engine Light
BRAVEST343
  • 1996 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 134,000 MILES
I have a 1996 Toyota Camry 4-Door Sedan L4-132 2164cc DOHC 5S-FE that has 134,000 Miles. Recently, a new catalytic converter was instaled and the back struts were changed. The air conditioner passed the test and was filled. Now, the catalytic converter makes a loud ticking sound when I turn off the car and the air condtioner does not work. When the new catalytic converter was instaled, should the oxygen sensors should have been changed being that they were old? What do you think is wrong with the A.C? Thank You!
Sunday, June 29th, 2008 AT 1:55 PM
The exhaust system has nothing to do with the AC system- Get your exhaust gases tested could be the converter is burning up again due to unburned fuel and replace the O2 sensor/s-
Sunday, June 29th, 2008 AT 7:39 PM
BRAVEST343
  • 8 POSTS
Sunday, June 29th, 2008 AT 8:26 PM
