Hi there,
for the valve stem seals the head has to come off and you may also have worn valve guides, the water pump & timing belt may be replaced as well and as for the other oil leaks you will have to get the engine washed and assessed as there are a number of placed that the oil can be coming from, these Jobs cant be estimated as there are to many variables, involved.
Mark (mhpautos)
SPONSORED LINKS
Sunday, August 31st, 2008 AT 9:58 PM
