1995 Toyota Camry oil leak
PILACINSKI
  • 1995 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 17,000 MILES
Engine leaking 1 quart every 300 mi. No smoke, good engine performance. All the cheap, accessible repairs done, gaskets.
mechanic says culd be v expensive to find leak.
any suggestions besides the obvious steam clean and track?
Wednesday, May 26th, 2010 AT 5:54 PM
  • 31,937 POSTS
Hi there,
That is the next step, I would be having a look at the bottom of the bell housing, rear mains do cause problems, also, front seal and cam seal, you will have to remove the top timing belt cover to get a look at the cam seal.
Mark (mhpautos)
Wednesday, May 26th, 2010 AT 6:32 PM
