1994 Toyota Camry spark
25,000 MILES • 4 CYL • FWD • AUTOMATIC
HUGH111653
engine cranks, won't fire on start fluid, rotor turns, has fuel pressure, no spark, ohm test coil OK, ohm test pickup coil. terminals G+ to G- test ok, terminals ne+ to ne- tests .432 k ohms, book says 370-550 ohms, is this a miss print, or is pickup coil bad? Also says I have to buy a new distributer if pickup coil is bad. This is an internal coil distributer
Mar 21, 2010 at 10:17 AM
  • 75,988 POSTS
Did you zero the ohmmeter when you were taking readings on the pick-up coil. also did you check the ignitor,
Those Ne and G signals goes to the computer when it recieves that signals the computer issues an Igt signal to the ignitor to fire the coil once this happens the ignitor gives the computer an Igf signal telling it that combustion has occured and repeats this process thruout the engine cycles-
Mar 21, 2010 at 11:23 PM
