HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Camry
Engine
Cylinder Head
Gasket
1994 Toyota Camry head gasket repair
GEEZYBABY81
MEMBER
1994 TOYOTA CAMRY
Engine Mechanical problem
1994 Toyota Camry 6 cyl Automatic
do I need a new head gasket if its cracked?
Friday, January 30th, 2009 AT 11:55 AM
MECHANIC
Hi there,
When ever the head is removed you will have to replace the head gasket the head will have to be checked for cracks and warp and re surfaced as well.
Mark (mhpautos)
SPONSORED LINKS
Friday, January 30th, 2009 AT 8:05 PM
Please
login
or
register
to post a reply.
Related Cylinder Head Gasket Content
What If I Only Put A Little Amount Of Head Gasket...
I Didnt Start The Car After I Put Some In. Thought The Radiator Was Low On Antifreeze But Once I Put Some Of The Sealant In The Radiator I...
Asked by
sunflowers30
1 ANSWER
1994
TOYOTA CAMRY
VIDEO
Can You Fix a Head Gasket with a Sealer?
Instructional repair video
GUIDE
Cylinder Head Gasket Blown Symptoms
A head gasket failure must be caught early to help protect the engine from additional damage. Understanding and recognizing these symptoms will be beneficial to your ...
1997 Toyota Camry Head Gasket
Engine Mechanical Problem 1997 Toyota Camry 6 Cyl Automatic We've Been Told We Need A New Head Gasket. Is That A Difficult Job? Could...
Asked by
Elliotfish
1 ANSWER
1997
TOYOTA CAMRY
2002 Toyota Camry Head Gasket Failure And Fix
Car Was Overheating Instantly. Head Gasket Failure Found, Early. It Was Found That The Engine Was Not Damaged, The Block Is Not Cracked...
Asked by
rrinternet
1 ANSWER
2002
TOYOTA CAMRY
1993 Toyota Camry How Many Heads In My Engine?
My Problem Began With Overheating, Then White Smoke Coming Directly Out Of The Engine. It Looked As Though The Smoke Was Coming From The...
Asked by
hotelsinger
1993
TOYOTA CAMRY
1993 Toyota Camry Cyclinder Head
Engine Mechanical Problem 1993 Toyota Camry 4 Cyl Front Wheel Drive Automatic Our Car Suddenly Stalled One Day With The Temp Gauge...
Asked by
jamie perry
1 ANSWER
1993
TOYOTA CAMRY
VIEW MORE
SPONSORED LINKS
Coolant Mixing With Engine Oil
Oil Life Reset Saturn Vue 2002-2007
Online car repair manuals
