2002 Toyota Camry Head Gasket Failure and Fix
2002 TOYOTA CAMRY
104,000 MILES • 4 CYL • 2WD • AUTOMATIC
RRINTERNET
Car was overheating instantly. Head gasket failure found , early. It was found that the engine was not damaged, the block is not cracked as suspected. Even if this is repaired, will I continue to have recurring problems with my engine related to this issue?
Nov 11, 2008 at 4:55 AM
  • 31,937 POSTS
Hi there,
If the cylinder head is repaired correctly and the cooling system is working as it should, there is no reason why you should have any further problems with the engine, in the short to long term.
mark (mhpautos)
Nov 11, 2008 at 9:33 AM
