Harmonic balancer pulley removal
1994 TOYOTA CAMRY
DOIRONMAN
Cannt get the nut to break loose. Am I going the wrong direction? Is it a reverse threaded bolt ? If not then please give me some hints as to how to get it loose?
Jan 18, 2010 at 3:50 AM
BLACKOP555
  • 10,386 POSTS
It is normal thread you may be able to wedge a flat bar into the flywheel where the starter goes or hit it with an impact gun. Here is a video of the job being done. It is on a different car but the procedure is the same.
https://youtu.be/NZIMNkLxCMA
Cheers
Jan 20, 2010 at 8:54 AM
MICHAEL RAMIREZ
Put a breaker bar on the bolt then rest it against the frame or something solid then turn the engine over using the starter, keep your hands away. Make sure it will go the right way before you hit the starter.
Mar 26, 2010 at 1:05 PM
MYNIC91
My son struggled to get the old harmonic balancer off; in order to replace it and two belts. Someone came to his rescue and said just turn the key to on position. That worked; it came right off after several hours of trying to unscrew a bolt in the center of the balancer. The problem is now the car feels like it is stuck at 20 mph, at times, or just has really slow pickup or no get-up-n-go. The car used to just go, when applying the breaks, without hesitation. This, obviously, prompted me to ask questions. So, the person who came to my sons rescue unplugged the distributor, instead of the battery, in order to turn the ignition to on without turning on the car. A clerk at the auto parts store found that a sensor, ported vacuum switch, next to the plug had been recently broken (the person unplugging must have used it for leverage), and a sensor plug next to it is damaged in a way that the wire slips upward, as if to come right out. My son said the plug with a lose wire used to have a clip and wont work without it. I replaced the ported vacuum switch, the clerk said the plug next to it will be fine, as long as the wire is in. (This has become costly for a single parent) But the problem of take off or timing, still persists; along with something I had been noticing since before the repairs made by my son. When I travel a short distance, like dropping my daughter off at school and coming back, then park the car and sit in it for a minute, I can hear the water/coolant gurgling into the back flow jug. I don't think the engine should be getting so hot, so soon. What do you make of these two issues? Is the lose plug wire a cooling sensor in need of replacement? Do you think something bad could've happened when my son was trying to force the old harmonic balancer off? Where did the car's get-up-n-go go?
Sep 7, 2018 at 11:11 AM (Merged)
HMAC300
  • 48,601 POSTS
The harmonic balancer thing should not have much to do with anything except removal. the wire connection should be definitely fixed and then it may be either a thermostat or a head gasket so have the coolant system pressure checked by a pro. Just a tip, auto parts clerks are just that, clerks not people who have actual real world experience.
MYNIC91
Thank you, Hmac!
GREGBRO
To remove harmonic balancer is it right hand or left hand thread?
  • 31,937 POSTS
Hi there,
This is a R/H thread and it will be very tight.
mark (mhpautos)
DOOGENTS
I was also having trouble with the harmonic balancer bolt. My air comp. turned off at 130psi, I have a 50' 3/8 hose and my 1/2 inch impact would not move it. Being in HVAC I have compressed nitrogen in my service van. I adapted my nitrogen regulator to take my air hose and put 200psi of nitrigen to my impact gun. It spun the bolt out as easy as anything.
Nov 6, 2018 at 7:32 AM
  • 55,432 POSTS
Great addition to this thread! Please feel free to help out whenever you are on the site :)
Cheers, Ken
Nov 9, 2018 at 4:26 AM
