1994 Toyota Camry Brake Lights
SLUMDUNK
  • 1994 TOYOTA CAMRY
  • 4 CYL
  • 180,000 MILES
Why is my red brake light keeps showing up on my dash board when Im driving? Its all the way to the off position and so many times I make sure its to down (off) position but still shows up.
Saturday, February 21st, 2009 AT 12:56 PM
TOYOTA19
Have you check brake pads or fluid level?
Thursday, April 16th, 2009 AT 11:19 AM
TRUSTME123
I am having this problem as well! I hope to hear some answers soon.
Www. Clearcutautoglass. Com - Auto Glass Replacement and Repair in Phoenix, AZ
Thursday, April 16th, 2009 AT 12:24 PM
CAMRY9299
I had this same issue a few months ago. It turned out I had a pin prick sized hole in the brake line that only leaked when I applied the brakes. I would suggest to you guys check every component of the brake system because that light means there is a problem and generally it is not the brake pads.
Wednesday, May 20th, 2009 AT 9:14 AM
