HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Camry
Engine Cooling
Radiator
1994 Toyota Camry
SMOKINLOUJOHN2006
MEMBER
1994 TOYOTA CAMRY
6 CYL
FWD
AUTOMATIC
106,000 MILES
Repaired the radiator an the motor still runs chugy and the anifreez is backing up
Tuesday, February 23rd, 2010 AT 6:45 PM
MECHANIC
Hi there,
Did you replace the thermostat? Also get a Co check done for a head gasket problem, these cars are known to do heads if they over heat to much.
Mark (mhpautos)
SPONSORED LINKS
Wednesday, February 24th, 2010 AT 4:47 AM
Please
login
or
register
to post a reply.
Related Radiator Content
1994 Toyota Camry Radiator Water Overflow When Long...
I Recently Bought This Car From A Private Seller.I Found Some Problem In My Car When Travekking To Long Distance. When Travelling To Long...
Asked by
aatootan
1 ANSWER
1994
TOYOTA CAMRY
GUIDE
Radiator
Radiators consist of a few basic parts, two tanks and the core. The radiator "tanks" located on the sides or top and bottom are used to attach upper and lower coolant hoses...
1996 Toyota Camry Radiater
What Causes The Raditer To Sound Like It Is Boiling Over When I Turn My Car Off? It Has Water And Coolient In The Car. Oil Is Fine, Water...
Asked by
suebell1953
1996
TOYOTA CAMRY
Radiator
My Car Was Over Heating And Keep Having To Put Coolant In Evry 15 Minutes. Monroe Said He Looked Underneath Car And Said Radiator Is Shot...
Asked by
Lafrance
1 ANSWER
1996
TOYOTA CAMRY
1995 Toyota Camry Smelly And Leakin
My 95 Camry Is Leakin Oil In To My Radiator As Well As On The Ground And Has A Bad Smell Like Either Fuel Or Oil Cant Really Tell. Is There...
Asked by
tater987
1 ANSWER
1995
TOYOTA CAMRY
1994 Toyota Camry Leaking Anti-freeze
My Girlfriends 1994 Toyota Camry 4 Cylinder Is Leaking Antifreeze. Its Leaking From The Back Of The Water Pump Where There Are Two Metal...
Asked by
stealth_1987
1 ANSWER
1994
TOYOTA CAMRY
VIEW MORE
SPONSORED LINKS
Radiator Replacement Mercedes Benz
Radiator Replacement Kia Sportage
Online car repair manuals
