Hi there,
This will take a mechanic 2 hrs or so, but if you have never done it allow an afternoon so not to rush things, you need to take off the plastic skirt on the lower frame, remove all drive belts, remove engine mount undo the front pulley bolt, (this is extremely tight) remove the plastic timing cover align the timing marks (see pic) back off tensioner, replace belt,(note do not turn engine or cam with belt removed) reset tensioner, check timing marks are correct turn engine over by hand 2 revolutions and re set tensioner again, (just back off bolt and do it up as this is automatic adjustment) re check timing marks and if all OK put it all back together again.
Mark (mhpautos)
SPONSORED LINKS
Friday, February 12th, 2010 AT 9:25 PM
