Raise and support front of vehicle.
Remove front wheels.
Remove both fender aprons.
Separate tie rod ends from steering arms.
Remove steering column hole cover for access to steering coupler bolts.
Mark and disconnect steering coupler "U" joint. Remove and plug pressure and return lines.
Remove air control vacuum valve hose (if equipped).
Mark and remove drive shaft.
Remove stabilizer bar (if necessary).
Remove steering gear mounting brackets.
Remove steering gear.
SPONSORED LINKS
Tuesday, December 15th, 2009 AT 7:40 PM
