1992 Toyota Camry Oil Leak
TUBASHAMAN
  • 1992 TOYOTA CAMRY
  • 4 CYL
  • 178,000 MILES
This is my first post. I bought a 1992 toyota camry, have had struts done, a CVR boot on the right side, and just had an oil leak fixed, or so I thought, they replaced the timing belt, front seal, camshaft oilseal, and the crankshaft oil seal (and waterpump).
I take it home, and it is still leaking heavily on the driveway like before. Where it is leaking, I am guessing it is the pan gasket, which they didn't apparently check. Im low on money after these repairs and I think I can do this. I don't know how to change the oil, but I will be willing to learn.
Can anyone tell me what I will need to replace the pan gasket, including socket sizes, and how to remove the oil and suck.
I really appreciate anyhelp, email at jmg04d@acu. Edu also if preferred
Friday, June 26th, 2009 AT 11:19 PM
  • 31,937 POSTS
Hi there,
Before tearing into the sump which is chemically sealed and normally never leaks, I would get the engine cleaned & checked for this oil leak first, check oil pressure switch, oil filter, sump plug first.
Mark (mhpautos)
Saturday, June 27th, 2009 AT 8:26 AM
TUBASHAMAN
Well this is a 1992, and the other seals and gaskets they needed to replace
Saturday, June 27th, 2009 AT 3:34 PM
