Engine Cooling problem
1991 Toyota Camry 6 cyl Two Wheel Drive Automatic
should any sealant be used with the gasket supplied and is there an easy way of fitting engine mount bracket without taking the engine out?
Thursday, July 30th, 2009 AT 11:19 PM
MECHANIC
Hi there,
If it is an "O"ring type seal no sealant just a little rubber grease or petroleum jelly grease so the seal dose not catch, for paper gaskets you can use a sealant. As the for the mount, you just have to support the engine with a jack and you can remove the mount.
