1991 Toyota Camry slow to heat
GRANDSONI
  • 1991 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 117,500 MILES
Bearly puts out heat. When the heater fan is turned on, the temperature gage drops back to cold. Is this an expensive repair?
Sunday, January 3rd, 2010 AT 3:16 PM
MERLIN2021
  • 17,250 POSTS
In your case I suspect either low coolant level, or faulty thermostat. Niether is too expensive, flush and fill with 50/50 mix, after you install the new tsat.
Sunday, January 3rd, 2010 AT 3:21 PM
GRANDSONI
Thank you for answering my concern. It was the coolant level. It is heating just fine now. Thank you again.
Tuesday, January 5th, 2010 AT 3:51 PM
MERLIN2021
  • 17,250 POSTS
Check for any leaks by pressure testing the cooling system!
Tuesday, January 5th, 2010 AT 5:17 PM
