I have 1 991 Camry with 110,400 miles on it. When you start the car up a small puff of blue smoke comes out, but that only happens when it is first started in AM. I park it in my driveway & there are no oil leaks & the pan is dry. I was told by toyota that it is the vavlve guide & not to worry because it only happens once in awhile. I do not want to have to get a vavle job done, for it will be expensive. What may be a solution to stop the smoke or is it something I DO need to worry about?
Also when the car goes between 50 & 60 it semi shakes. The tires are balanced & new, What could that be? Please help. Thank you.
SPONSORED LINKS
Thursday, November 13th, 2008 AT 9:36 AM
