1991 Toyota Camry fuel pump
LARRY QUACK
  • 1991 TOYOTA CAMRY
  • 4 CYL
  • 120,000 MILES
Remove and replace fuel pump
Wednesday, September 1st, 2010 AT 7:02 AM
  • 31,937 POSTS
Hi there,
This is an in tank fuel pump, the fuel tank ha stop be removed and the pump is accessed from an access port on the top of the tank, undo the fuel lines. Electrical connections and undo the screws that hold the pump housing down, the pump is mounted with in the sender unit.
Mark (mhpautos)
Wednesday, September 1st, 2010 AT 7:29 AM
