replace or repair fuel pump
255,000 MILES • 2.4L • 4 CYL • FWD
JOE1953
  • 812 POSTS
if the fuel pump is bad do i have to replace just the fuel pump or do i need to replace the fuel pump hold assembly?
Oct 23, 2016 at 4:59 AM
HMAC300
  • 48,601 POSTS
some the pump can be changed and others the whole pump /sending unit assembly. yours the pump is available separate.
Oct 23, 2016 at 7:49 AM
JOE1953
  • 812 POSTS
where is the best place to go online and buy the fuel pump?
Oct 23, 2016 at 1:34 PM
HMAC300
  • 48,601 POSTS
check the fuel pressure to verify as it may not be the problem.
Oct 23, 2016 at 11:50 PM
JOE1953
  • 812 POSTS
i didn't check the fuel pressure this car don't have a fuel pressure test port and the tester that i have it fit a test port, on this car look like i have to disconnect the fuel line and connect a fuel pressure test to the fuel line. when i turn the key to run i don't hear the fuel pump relay click and i use a test light and check for power at the relay and there is no power, i can take the fuel pump relay out and turn the key to run the fuel pump will run and want cut of until i turn the key of the engine starts but stop immediately when the engine stop i can hear the fuel pump run for a few second and cut of can you explain to me what is happen why it no power at the fuel pump relay and what turn the relay on and the fuel pump and what keep the fuel pump running?
Oct 24, 2016 at 11:09 AM
HMAC300
  • 48,601 POSTS
try resetting security system that may be the problem. see link
https://www.2carpros.com/articles/how-to-reset-a-security-system
Oct 24, 2016 at 10:34 PM
JOE1953
  • 812 POSTS
Is this the procedure i use to reset the security system
TOYOTA LEXUS IMMOBILIZER RESET
We called the dealer here is their response: Lock the car and shut all doors, then use the key to unlock the driver's door. Push and hold down the panic button on the remote. With no one in the car lock and unlock the car using the key remote. Disconnect the battery and reconnect as a last resort.
Oct 25, 2016 at 1:42 AM
HMAC300
  • 48,601 POSTS
I guess if that is what the dealer told you the link I sent also covers toyota
Oct 25, 2016 at 2:28 AM
JOE1953
  • 812 POSTS
i did the reset test on the security system it didn't help my problem the car is still doing the same thing i need to know why i don't hear the fuel pump relay click when i turn the key to on what i need to check? but if the fuel pump don't run when i turn the key to run i wan't be able to check the fuel pressure i believe the fuel pump suppose to run for about 2 seconds but it not coming on when turn the key on why?
Oct 25, 2016 at 11:08 AM
HMAC300
  • 48,601 POSTS
it can be a bad relay, no power coming through the connection etc. you'll have to test for that.
Oct 25, 2016 at 11:26 PM
JOE1953
  • 812 POSTS
where is the relay located? I'm not sure i have located it the relay i though that was it i switch relay that didn't help do the relay suppose to click when i turn the key on or do it click when the engine is cranking? the relay i thought was it i remove that one and turn the key to on i can hear the fuel pump run but when i put that relay back in the fuel pump want run i don't understand that.
Oct 26, 2016 at 12:47 AM
