Engine temperature is good, as well as the battery.
Fuel filter is new, ive pulled out the fuel pump inside the tank, and tested the pressure, its only running on 15 to 30 psi, no filter and regulator), do you reckon I should replace the pump? Thanks
SPONSORED LINKS
Tuesday, February 17th, 2009 AT 4:39 AM
