1990 Toyota Camry Timing
SAETTONE
  • 1990 TOYOTA CAMRY
  • 4 CYL
  • 250,000 MILES
I have no power after setting the timming. I followed the instructions on the lable under the hood. When I insert the jumper into the connector like the lable says, the RPM's go way down and the timing was set at 10 BTC. I set it to 0 BTC, pulled out the jumper, the RPM's went back up but the timing said @10~15 BTC and there is no power when driving.
Friday, June 18th, 2010 AT 2:30 PM
With the jumper on it should be 10deg BTDc and advances when unjumpered
Friday, June 18th, 2010 AT 3:57 PM
SAETTONE
I set it back to 10 and its ok now. Why would the label say to set it at 0 with the jumper in? I also read in the manual, when the jumper is inserted that the RPM's should rise then return to normal, not decrease as it did in my case.
Saturday, June 19th, 2010 AT 8:54 PM
