1989 Toyota Camry Distributor/Timing???
230,000 MILES • 4 CYL • 2WD • AUTOMATIC
GRIFFO
The Camry had been running fine. I had just been for a short drive. Got home and wad idleing roughly out of the blue. I heard a loud banging noise. I pulled out the distributor and it was cracked at the shaft. Replaced the distributor and the car will not start. The engine turns over but no fire. I have checked and there is spark. Gas (LPG) tank is full. A mechanic friend (without seeing it) said that it may have slipped a timing tooth. Do you think the car is repairable, and if so, at what price? Do you have any suggestions?
Jun 30, 2008 at 7:42 PM
MMPRINCE4000
  • 8,548 POSTS
Remove all spark plugs and rotate engine by hand with a ratchet and socket on the balancer pulley until you feel air coming out #1 cylinder, rotate slightly until crankshaft timing mark is aligned with mark on engine (TDC#1).
Remove dist. cap, dist. rotor should be pointing directly at #1 cylinder on cap, if not, remove dist. and rotate and install so it does point to #1.
Jun 30, 2008 at 10:07 PM
