How long does it take to remove and put back on.
RACER007
  • 1990 TOYOTA CAMRY
How long does it take to remove and put back on a water pump and what does it take to do the job?
Saturday, April 25th, 2009 AT 4:11 PM
BMRFIXIT
  • 19,053 POSTS
Removal (Camry)
Drain cooling system. Remove timing belt and pulleys. . Disconnect radiator hose at water pump. Disconnect coolant temperature switch connector from coolant inlet housing.
Disconnect coolant by-pass pipe from water pump. Remove retaining bolts, water pump and gasket. If necessary, remove cover from water pump.
About 4 hours to do
Saturday, April 25th, 2009 AT 4:39 PM
