HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Camry
Emission
Smog
Fail
1990 Toyota Camry
CHAKYANTSANG
MEMBER
1990 TOYOTA CAMRY
4 CYL
FWD
AUTOMATIC
190,000 MILES
Failed emission test
Saturday, January 31st, 2009 AT 10:45 PM
MECHANIC
Hi there,
The first thing to do is make sure that it is not a tune issue that is causing your problem, do a full tune up and check for any set fault codes first, start here.
Mark (mhpautos)
SPONSORED LINKS
Saturday, January 31st, 2009 AT 10:59 PM
Please
login
or
register
to post a reply.
Related Smog Fail Content
My Car Did Not Pass Smog Due To The Hc Being High
Could It Be Because Or The Catalytic Converter Or Bad Mass Airflow Sensor? Hi Hows It Going I Have A 1992 Toyota Camry Le That Did Not...
Asked by
sergio138
1992
TOYOTA CAMRY
95 Camry Le 6 Cyl. 3.0; 250k, Failed Emission Test...
My 95 Camry Runs Great But I Just Failed An Emission Test In Ohio For Nitrogen/oxygen Compounds (nox). The Oxygen Sensor Has Needed...
Asked by
pkeenan266
1 ANSWER
1995
TOYOTA CAMRY
Help With 1997 Camry That Failed Ca Smog Test Twice
Hello, This Is My First Post In The Forum. I Have A 1997 Camry Xle (v6) With 140,000 Miles On It That Failed Its Smog Test Twice. Here...
Asked by
SoCal
1997
TOYOTA CAMRY
1995 Toyota Camry Just Barely Failed Smog On Co%
I Failed The Ca Smog Test With Co Percentages Of.47 (15 Mph) And.46 (25mph) And Then Got It Tuned Up - Timing And Spark Plugs Is All I Know...
Asked by
george.catlin
1 ANSWER
1995
TOYOTA CAMRY
Failed Smog Computer Problem?
My Car Did Not Pass Smog So I Took It Into The Shop. My Mechanic Says That The Catalytic Converter Is Working, That The Emissions Are Fine...
Asked by
Gretch1234
1 IMAGE
1999
TOYOTA CAMRY
VIEW MORE
SPONSORED LINKS
Code Read Retrieval/Clear - Dodge Stratus
How to Clear a Check Engine?
Online car repair manuals
