Hi george. Catlin@gmail. Com, Welcome to 2carpros and TY for the donation.
Best have the coolant temperature sensor and oxygen sensor checked and tested if its within swtching accordingly and also the air injection system before you consider replacing the catalytic converter-Yes, the Cat can also be the problem to raise the CO along with the HC
SPONSORED LINKS
Thursday, August 26th, 2010 AT 6:37 PM
