1989 Toyota Camry Starter?
RLESINK
  • 1989 TOYOTA CAMRY
Engine Mechanical problem
1989 Toyota Camry 6 cyl Automatic 110000 miles
When I start my car sometimes it makes a hi-pitched screech. This might happen once or twice before it actually starts.
I had an 88 Camry which developed this same issue. Replaced the start about 3 different times and it never fixed it. Is there another issue which could be causing this?
I think I read somewhere It might be the flywheel? If this is the case, how much does it cost to replace the flywheel / whatever part may be bad.
Thursday, July 31st, 2008 AT 2:38 PM
  • 31,937 POSTS
Hi there,
It may be that the drive plate is damaged & the starter drive is slipping, the transmission has to be removed to do this, I will post an estimate when I can get access to the data base later today (my time)
Mark (mhpautos)
Thursday, July 31st, 2008 AT 5:58 PM
