HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Camry
Engine
Symptoms
Oil Leak
1989 Toyota Camry oil leak
WONGRANGER
MEMBER
1989 TOYOTA CAMRY
Engine problem
1989 Toyota Camry V6 Front Wheel Drive Automatic 145923 miles
I changed the gaskets of valve covers, but still have leaks of 4 to 5 drops each day
What do u know as a common problem with this year and model.
Monday, December 3rd, 2007 AT 1:02 PM
MECHANIC
Could be coming from the oil filter, front and rear seal, distributor, oil pressure sending unit
Monday, December 3rd, 2007 AT 2:21 PM
Please
login
or
register
to post a reply.
Related Engine Oil Leak Content
1989 Toyota Camry Oil Leak
Hi There Is A Oil Leak In My Toyota Camry Its Not Coming From The Oil Pan Or Drain Bolt Or The Valve Cover Or Oil Filter I Do Not Know Where...
Asked by
Avengedsario
1989
TOYOTA CAMRY
GUIDE
Engine Oil Leak
A car engine uses motor oil to lubricate the internal moving parts of the engine such as crankshaft, rod bearings, pistons and valve train. This oil is controlled from...
1994 Toyota Camry Engine Oil Leaks
I Was Told My Car Has An Engine Oil Leak And To Fix It Timing Belt And Drive Belt Along With Outside Gaskets Need To Be Replaced. Also...
Asked by
Geminix6570
1 ANSWER
1994
TOYOTA CAMRY
2003 Toyota Camry Coolant And Engine Oil Leak
Engine Cooling Problem 2003 Toyota Camry 4 Cyl Automatic 85000 Miles Hi I Have Noticed The Car Engine Temp To Fluctuate To High And...
Asked by
Chan1234
2003
TOYOTA CAMRY
1998 Toyota Camry Oil Leak
We Have An Oil Leak At A "fitting" On The Front Of The Engine, Passenger Side Just Below The Head Gasket. The Oil Just Squirts Out At The...
Asked by
owen0118
1998
TOYOTA CAMRY
2007 Toyota Camry Leaking Oil?
There Are No Signs Of An Oil Leak But After The Oil Change, Two Or Three Weeks After, I Need To Add One Or Two Quarts Of Oil. The Smoke...
Asked by
vacevedo999
1 IMAGE
2007
TOYOTA CAMRY
VIEW MORE
Crankshaft Main Seal Replacement - Front
Crankshaft Seal Replacement - Rear
Can You Fix a Head Gasket with a Sealer?
