1989 Toyota Camry gear not engage from shift selector
185,000 MILES • 4 CYL • 2WD • AUTOMATIC
89CAMRYWAGON
  • 14 POSTS
I got no engagement of gears with shift selector in any of the positions (D, R, 2 or L). Shifting action is smooth. With the engine running, the car is not moving at whatever position if shift to. Also, shift indicator on the dash is not showing for R when I shift to that position. All other positions are ok, i.e. dash indicator would show(light up) at P if I shift to P, ect.
With the shifter at park position I can still push the car arond as though the parking mechanism is not engaging
This all started when I was starting out at a stop light and suddenly the car won't move when I step on the gas pedal.
Appreciate any tips.
Jan 30, 2010 at 4:17 AM
89CAMRYWAGON
  • 14 POSTS
found the problem...dang...:D
Mar 6, 2010 at 10:10 AM
JLEJ
could you tell us what it was you found... we seem to have the same problem... thx
Mar 9, 2011 at 4:14 PM
89CAMRYWAGON
  • 14 POSTS
Driver-side transaxle has the transmission-side slipped of of the transmission "socket". If you have taken a transaxle out and then put it back, chances are you might not have push the transmission-side of the transaxle all the way and it has slipped. That was my problem, exactly.
Mar 9, 2011 at 4:38 PM
FIXITMR
  • 9,989 POSTS
so are you saying you took out the axle/replaced and that's why it slipped?
Mar 31, 2011 at 1:36 AM
89CAMRYWAGON
  • 14 POSTS
right. I did not put the axle back properly the first time which then caused the slip off.
Mar 31, 2011 at 10:11 AM
FIXITMR
  • 9,989 POSTS
thanks for your informative input.
Apr 1, 2011 at 10:21 AM
