1987 Toyota Camry
STEPHEN CANADY
  • 1987 TOYOTA CAMRY
  • 4 CYL
  • 201,336 MILES
It will crank up and run fine when its cold and you can drive it will not cut off but when you turn it off you have to wait until it cool off before it will crank again. I changed the wires dist, cap and plugs I never had this happen before
Saturday, December 19th, 2009 AT 8:16 PM
KHLOW2008
  • 41,814 POSTS
Hi stephen canady,
Thank you for the donation.
Do you mean the starter would not crank when engine is hot?
Quite often cranking is mistaken for firing up so I need to make sure I understand your question correctly.
Here are links that you can use to check what is missing causing it not to start.
https://www.2carpros.com/kpages/first_things.htm
https://www.2carpros.com/first_things/car_will_not_crank.htm
https://www.2carpros.com/first_things/car_cranks_but_wont_start.htm
Let me know more about the symptoms so that I can assist you in getting it started.
Is this a carburetted or injection model?
Saturday, December 19th, 2009 AT 10:54 PM
