Hello, My 1984 Camry has a rough idle, sometimes flucuates, also surges while driving under load. Has new- Fuel Pump, Fuel Filter, Pressure regulater, Air Filter, Coolant sensor, coolant sender, battery, timing belt, Rebuilt distributor, new TPS, new muffler, New Cap, rotor, wires, plugs, air filter, timing is correct. I have checked for intake leaks and found none. Any help would be greatly appreciated, maybe EGR valve, or IAC? Bad Catalytic converter? Thanks, Rob
SPONSORED LINKS
Tuesday, June 8th, 2010 AT 5:56 PM
