2001 Toyota Avalon Tail Light Install Fix
WIREBENDER
Having recently purchased the rear tail light assembly (passenger side) for my 2001 Toyota Avalon I now need to know how to install it. Are any special tools required? Any direction is appreciated. Thanks
2001 Toyota Avalon, 92K miles, 6 cylinder
Oct 29, 2007 at 5:14 AM
2CARPRO JACK
  • 11,533 POSTS
Probably a 10mm deep socket is all it will take. Unbolts from inside the trunk, might have to move some carpet or plastic covers to get to the bolts
Oct 29, 2007 at 5:16 AM
Suggested Repair
Install the passenger rear tail light from inside the trunk with a 10mm deep socket. Move carpet or plastic covers as needed to reach and unbolt the assembly.
Conversation Summary
The owner of a 2001 Toyota Avalon with 92,000 miles bought a passenger-side rear tail light assembly and asked how to install it and whether special tools are needed. The expert said a 10mm deep socket should be enough, and that the assembly unbolts from inside the trunk after moving carpet or plastic covers to reach the bolts.
