Avalon Tail lights
JETSON
I have a 1997 Avalon V6. The tail lights and license plate light stopped working. The fuse is good and the bulbs are good. All other lights work correctly. Is it possible the relay is bad. If so where is it located?
May 7, 2007 at 8:04 AM
  • 75,988 POSTS
[quote:f481e16776="jetson"]I have a 1997 Avalon V6. The tail lights and license plate light stopped working. The fuse is good and the bulbs are good. All other lights work correctly. Is it possible the relay is bad. If so where is it located?[/quote:f481e16776]
Its on the rear of the instrument panel junction box
May 7, 2007 at 10:57 AM
JETSON
[quote:296fee7e5d="rasmataz"][quote:296fee7e5d="jetson"]I have a 1997 Avalon V6. The tail lights and license plate light stopped working. The fuse is good and the bulbs are good. All other lights work correctly. Is it possible the relay is bad. If so where is it located?[/quote:296fee7e5d]
Its on the rear of the instrument panel junction box[/quote:296fee7e5d]
Do I remove the instrument cluster or is that in the engine compartment?
May 7, 2007 at 11:42 AM
  • 75,988 POSTS
[quote:45ee49b586="jetson"][quote:45ee49b586="rasmataz"][quote:45ee49b586="jetson"]I have a 1997 Avalon V6. The tail lights and license plate light stopped working. The fuse is good and the bulbs are good. All other lights work correctly. Is it possible the relay is bad. If so where is it located?[/quote:45ee49b586]
Its on the rear of the instrument panel junction box[/quote:45ee49b586]
Do I remove the instrument cluster or is that in the engine compartment?[/quote:45ee49b586]
Its behind the instrument panel in the vehcle look for a junction box-where fuses/relay/circuit breakers are.
May 7, 2007 at 2:20 PM
