1998 Toyota Avalon radiator problem
1998 TOYOTA AVALON
MARKZZZZZZ
Other Category problem
1998 Toyota Avalon V6 Front Wheel Drive Automatic 80000 miles
my wife hit a truck and puntured her radiator.replaced it and started leaking at the bottom middle of radiator.replaced it and 3 days later ,same place but gushing out where pulled apart at bottom middle.
i think it is a cheap radiator from RADIATOR EXPRESS ON LINE. WE NEVER HAD A PROBLEM BEFORE.THEY KEPT MY 180.00 ,BECAUSE THEY SAY IT IS MY PROBLEM NOT THEIRS.....DOES ANYONE KNOW WHAT MIGHT BE CAUSING THIS PROBLEM......tried to talk to them for the last 3 months and they just rip you off and say they will let you know and dont' bother them anymore...BEWARE OF RADIATOR EXPRESS...SELLS JUNK AND DOES NOT HONOR THEIR RADIATORS IF YOU HAVE A PROBLEM.
Dec 8, 2007 at 7:37 AM
BLACKOP555
  • 10,386 POSTS
sounds to me like you got sold a pile of garbage, first check the compression on the cylinders, you may have a bad headgasket, casuing immense pressure to build up in the radiator, causing it to burst.
Dec 8, 2007 at 10:06 AM
