1998 Toyota Avalon PO401 Insufficient Flow
1998 TOYOTA AVALON
RELOWRIE
On the V6 Engine in my 1998 Avalon I recieved error code PO401 several months ago, based on Service manual repair procedures, i evauated then replaced, the EGR Valve Assembly, Position Sensor, VSV Valve, Temp Sensor, PVC Valve, and anything i could find in the chain of parts having to do with EGR. The code went away for a week or so after each replacement. ( i don't think any of the parts were defective itest them off the car and they test fine) then the code returned, If i take everything apart again and reset the code it will go away for a few days or week, but then returns and when i reset it will then return, the frequence of return increases untill i take things apart again. I am totally baffeled, any ideas!!!!!!
Feb 7, 2007 at 7:34 PM
GARFIELD
  • 197 POSTS
pull your egr valve off and check the ports in the manifold and piping to ensure that they are not plugged with carbon.
Feb 8, 2007 at 8:11 AM
Garfield-I believe you nailed this one big time.
The flowmeter will snitch on this to include the O2
Feb 11, 2007 at 6:08 AM
