2000 Toyota Avalon P0172 and P0471 codes
130,500 MILES • 6 CYL • FWD • AUTOMATIC
KENNER2
I have a P0172 and P0471 code on diagnostics, and at a redlight when trying to excelerate fast my engine bogs down heavily, and it takes a little distance before it begins to accelerate. Could it be the "System too rich (bank one)" and a possible Oxygen Sensor. The MAF sensor was changed at 120,000 miles during a tune up. Once repaired how can I reset the Check Engine Light?
Ken Sherman
Oct 23, 2008 at 7:23 AM
  • 75,988 POSTS
Hi kenner and welcome to 2carpros
P0172
Possible causes include a bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode.
P0471 Exhaust Pressure Sensor Range/Performance check the exhaust for restriction-could be the converter clogging up and creating excessure pressure or the sensor itself/wiring/computer
Once repaired how can I reset the Check Engine Light? Remove the EFI fuse for 10secs- or disconnect the battery
Oct 23, 2008 at 7:55 AM
