1996 Toyota Avalon starting click only
1996 TOYOTA AVALON
ROBERT IN NAPLES
Electrical problem
1996 Toyota Avalon 6 cyl Two Wheel Drive Automatic 139k miles
I try to start my car, turn key and hear a click only. I take the vehicle out of park and throw it in neutral and it starts only if I move gear shift up and down to find sweet spot. I had this trouble before with a Camry. Thanks
Apr 1, 2008 at 11:33 AM
MASTERTECHTIM
  • 4,750 POSTS
moving the shifter is not actually doing anything, just coincidence. replace the starter motor. the starter solenoid has burn marks on it from use over time and it makes it harder and harder to make a good contact. starter repalcement is the only option. hope this helps
Apr 1, 2008 at 11:36 AM
