1997 Toyota Avalon
CLEMENTE34
  • 1997 TOYOTA AVALON
Shakes or Wobbles problem
1997 Toyota Avalon 6 cyl Two Wheel Drive Automatic
AT 60-65MPH CAR STARTS TO SHAKE
Friday, August 13th, 2010 AT 12:37 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Typically, this is an indication that you need to have the tires balanced. But, it could be a bent rim or even another suspension component causing the vibration. Even other driveline components can cause vibration. Start with a good tire balancing
Friday, August 13th, 2010 AT 12:39 AM
