Headlight problem
2010 TOYOTA
8,000 MILES • 1.5L • 4 CYL • TURBO • 2WD • AUTOMATIC
SAMIDHAKA
Dear Sir,
I have Toyota Allion new shape with HID lights. When i switch on headlights after some time its start fluctuating and then turning off. Then i switch off the head lights and switch on again then it start working. After some intervals i have to repeat this. Pls. identify the problem.
Thanks in advance. Sami
Mar 10, 2014 at 8:07 PM
KNOWLEDGE IS POWER
  • EXPERT
  • 1,136 POSTS
Most likely it's the ballast heating up and shutting off
Mar 10, 2014 at 9:41 PM
SAMIDHAKA
Dear Sir,
I have changed both bulbs and changed the blaster also now even i have the same problem. I am very worries about this can you pls. quide me what is problem as here no mechanicz has found the solution.
Thanks a best regards
Sami
Apr 14, 2014 at 6:26 PM
KNOWLEDGE IS POWER
  • EXPERT
  • 1,136 POSTS
Have them test power and ground at the light assemblies to see if it fluctuates.... that will at least let you know if the lights are getting full power or if it is in the delivery. Also test at the switch
heres a guide on how to use a meter to check voltage, it will help
Feb 18, 2019 at 7:02 AM
