1996 Toyota 4Runner No Crank Loud Noise
HEATHER5743
I drive a 1996 Toyota 4runner SR5 with 121,000 miles, 4 wheel drive.
Sometimes I go to start my truck, and it doesn't crank. The lights come on inside the vehicle (like the brake, check engine, seatbelt lights...etc.).
Then other times it will start, but makes a really loud noise. It's coming from the front of the truck, but I'm not exactly sure where it is.
Another day I started it, and it was making that loud noise and the brake light came on. So I checked my parking brake and brake fluid, and both were fine. I let the truck keep running, then all of the sudden the check engine light flashed once, the car cranked and then the loud noise stopped and the brake light disappeared and everything was fine.
Do you have any idea what could be going on?
And just to let you know, I've recently replaced the battery and alternator.
Thanks for your help!
Jul 11, 2007 at 5:38 PM
  • 31,937 POSTS
G'day Heather,
Is the noise when cranking or when the engine has started?
The no start could be a faulty starter motor, a poor conection in the starter solinoid, starter relay or even a loose battery terminal, the noise could be the starter stuck in mesh when the engine has fired, this can make a terrible noise.
MARK (MHPAUTOS)
Jul 11, 2007 at 5:50 PM
Suggested Repair
Check the starter motor, starter solenoid connections, starter relay, and battery terminals. The loud noise may be the starter remaining engaged after the engine starts.
Conversation Summary
The owner of a 1996 Toyota 4Runner with 121,000 miles reports intermittent no-crank starts despite dash lights coming on, plus a loud noise from the front when it does start. The brake and check-engine lights once appeared during the noise, then cleared when the noise stopped. The battery and alternator were recently replaced. The expert asks whether the noise occurs while cranking or after the engine starts, and suggests a faulty starter, poor starter solenoid or relay connections, a loose battery terminal, or a starter stuck in mesh.
